Solidata K5 64GB
Solidata K6 128GB
Solidata K5 64GB
Solidata K6 128GB
The Slc looks pretty good!
Any idea on pricing or availability?
Less is more.
yeah they are just rebadged indlininx drives...according to this anyway
I´m only find german (european) prices.
http://winkom.eu/5.html
same controller. The 32GB MLC is mroe expensive than a Vertex of same size. But the 64 and 128 sizes are a bit cheaper.
All of the SLC drives are cheaper than the Vertex EX versions.
But if you notice, the stated specs are quite different. Just cause it uses the same controller doesnt mean it is the exact same drive. They might have a slightly different ammount of cache, or use different density nand chips, stacked differently, different PCB design, different quality nand, etc. The specs look better on these Solidata drives, and for the most part they are cheaper than OCZ. But with OCZ you know exactly what you are getting, have great support, and regular firmware updates.
Rig 1:
ASUS P8Z77-V
Intel i5 3570K @ 4.75GHz
16GB of Team Xtreme DDR-2666 RAM (11-13-13-35-2T)
Nvidia GTX 670 4GB SLI
Rig 2:
Asus Sabertooth 990FX
AMD FX-8350 @ 5.6GHz
16GB of Mushkin DDR-1866 RAM (8-9-8-26-1T)
AMD 6950 with 6970 bios flash
Yamakasi Catleap 2B overclocked to 120Hz refresh rate
Audio-GD FUN DAC unit w/ AD797BRZ opamps
Sennheiser PC350 headset w/ hero mod
But Solidata use the better Flashtools
Latest Vertex flasher works with a bootable USB drive and doesn't mess with your data.
